97 hood on a 94 camry?
I got a hood off a 97 camry at a wrecking yard and my bad I didn't check to see if it was compatible with a 94 camry. Does anyone know how they are different it will not close and lock on the hood latch. But since the car was hit in the front I cant tell if it is the frame I need to bend more to line it up?
The 97 is a different generation of Camry.
Is the frame bent or just the upper radiator mount sheet metal where the hood latch is? |
Took care of it
Just a follow up on this I did find out that the hood was a 96 not a 97 and I bent the upper sheet metal and it now works great thanks:)
great!Hope that work 100% again. Can you tell us what metal sheet did you bent?
