97 hood on a 94 camry?
Old May 2, 2012 | 10:24 AM
Lucky325712's Avatar
Default 97 hood on a 94 camry?
I got a hood off a 97 camry at a wrecking yard and my bad I didn't check to see if it was compatible with a 94 camry. Does anyone know how they are different it will not close and lock on the hood latch. But since the car was hit in the front I cant tell if it is the frame I need to bend more to line it up?
Old May 2, 2012 | 11:21 AM
The 97 is a different generation of Camry.
Is the frame bent or just the upper radiator mount sheet metal where the hood latch is?
Old May 8, 2012 | 10:42 AM
Default Took care of it
Just a follow up on this I did find out that the hood was a 96 not a 97 and I bent the upper sheet metal and it now works great thanks
Old May 10, 2012 | 10:13 PM
full house's Avatar
great!Hope that work 100% again. Can you tell us what metal sheet did you bent?
lenny
Nov 5, 2009 08:18 PM
eloso
Sep 15, 2009 11:02 PM
musicgold
Apr 22, 2009 02:03 PM
qtownhb
Mar 5, 2007 04:21 PM
Racecrafter
Feb 2, 2007 03:53 PM
