Interior
I have a 99 cam and i was wondering if anyone knew how to change the lights on the cluster. What I am talking about is I want to change the green where the odometer is to blue, and I was wondering if you could change the green on the side of the gauge cluster where it has park,reverse,drive, ect. as well? Thanks
RE: Interior
There are typically two screws at the top of the cluster that need to be removed, look at the guages then up. Once removed depending on the year there may be a panel surrounding the cluster that is held in with clips molded into the panel. Use a taped flat screw driver to gently pry out the panel, the tape will protect the finish.
The dealer sells stock bulbs if you want color start checking around. Suggest a Google search, there will be vendors that sell these. |
RE: Interior
Alright thanks man, does anyone know of any good sites that sells them?
RE: Interior
Also while I am on the subject of the guages does anyone know of a good site that has the red needle kits for the 97-01 Cams? I've seen several but the needles are really bright, I want more of a stock look.
