Interior
Old Mar 14, 2008 | 09:50 AM
Codeair2000's Avatar
Default Interior
I have a 99 cam and i was wondering if anyone knew how to change the lights on the cluster. What I am talking about is I want to change the green where the odometer is to blue, and I was wondering if you could change the green on the side of the gauge cluster where it has park,reverse,drive, ect. as well? Thanks
Old Mar 14, 2008 | 10:46 AM
Default RE: Interior
There are typically two screws at the top of the cluster that need to be removed, look at the guages then up. Once removed depending on the year there may be a panel surrounding the cluster that is held in with clips molded into the panel. Use a taped flat screw driver to gently pry out the panel, the tape will protect the finish.
The dealer sells stock bulbs if you want color start checking around. Suggest a Google search, there will be vendors that sell these.
Old Mar 14, 2008 | 12:08 PM
Alright thanks man, does anyone know of any good sites that sells them?
Old Mar 14, 2008 | 12:21 PM
Also while I am on the subject of the guages does anyone know of a good site that has the red needle kits for the 97-01 Cams? I've seen several but the needles are really bright, I want more of a stock look.
speedway
Jul 17, 2013 05:20 AM
SupermanVR
Aug 23, 2007 07:57 AM
04LEzeeroe
Jun 24, 2007 11:01 AM
shellyy29
May 13, 2007 12:08 PM
v8shadow
Jul 13, 2006 11:53 AM
