confused
i bought a 09 camy and im confused cause to listen the music normal i have to put the volume over 40 also my aux comes and goes i hit the aux button alot of times some times it comes on and then it doesnt ..my main question is ,is my radio gone bad? it look like the previous owner had a aftermarket system in the car....PLEASE HELp!!!!!...also what is a radio setting condeser relay and where is it located?
Where did you come up with the term radio setting condenser relay?
Does the stereo have a CD or tape player and is the volume normal when using these? What brand and model of stereo? |
I was looking on eBay for a radio & I came across that relay so I thought that could b a problem which I really don't know also I have the factory original radio in the car & the volume does the same with the cd or radio also it has the aux separate in a compartment below & it doesn't wanna work
Please clarify.
The radio is stock. The previous owner added what additional items? More speakers, additional amp, Etc. |
Yes its a stock radio look like the previos owner messed with the radio cause when i was gonna remove it to c id my aux was..loose the radio had One bolt holding it...i also saw amp wiring in trunk so i really.dont know id radio is any good
The unit in the dash is wired to the amp in the trunk. Check wire connections at each location.
The amp in the trunk would have a part number. If the amp is blown the sound level will be greatly reduced. |
Ok the previos owner did not leave amp just wiring all over car i took it out so there wasn't any fuse
If wires are all over the place perhaps this is the problem.
Toyota had two types of radios. One had the amp built into the radio in the dash, the other had a remote amp controlled by the head unit in the dash. The remote amp may be under the passengers seat. There may have been a CD player in the trunk. |
