HELP with 1997 Camry new radio installation
I took my old radio out today (the factory radio), and went to install the new one.
During the course of hooking up the wires, there was a "spark" from a wire (oops). Now, the "constant power" blue wire doesn't have power. The grey wire that provides power when the key is in the ignition works fine, and can power the radio. But the constant power when the car is off no longer works. I'm thinking I blew the fuse during installation? Where is the fuse for this blue wire?!? I've checked all the fusesbehind the coin tray, and they all seem to be good. Any help would be appreciated! |
RE: HELP with 1997 Camry new radio installation
Never mind - found it.
I did the same thing. Which fuse is it?
Under the hood near the driver's side is a fuse box. I believe the fuse you want is called "radio 1".
My initial problem was that I was looking at the fuses behind the little change holder to the left of the steering wheel. Nope - the fuse I wanted was under the hood. Hope this helps! |
