HELP with 1997 Camry new radio installation
Old Dec 27, 2007 | 09:53 PM
cruizr's Avatar
Default HELP with 1997 Camry new radio installation
I took my old radio out today (the factory radio), and went to install the new one.
During the course of hooking up the wires, there was a "spark" from a wire (oops). Now, the "constant power" blue wire doesn't have power.
The grey wire that provides power when the key is in the ignition works fine, and can power the radio.
But the constant power when the car is off no longer works. I'm thinking I blew the fuse during installation? Where is the fuse for this blue wire?!?
I've checked all the fusesbehind the coin tray, and they all seem to be good.
Any help would be appreciated!
Old Dec 28, 2007 | 09:17 AM
cruizr's Avatar
Default RE: HELP with 1997 Camry new radio installation
Never mind - found it.
Old Jan 14, 2008 | 01:57 PM
joshadude's Avatar
I did the same thing. Which fuse is it?
Old Jan 14, 2008 | 07:41 PM
cruizr's Avatar
Under the hood near the driver's side is a fuse box. I believe the fuse you want is called "radio 1".
My initial problem was that I was looking at the fuses behind the little change holder to the left of the steering wheel. Nope - the fuse I wanted was under the hood.
Hope this helps!
lmary
Aug 1, 2009 08:19 AM
xNOxSK1LLZx
Feb 24, 2009 10:38 AM
betacrash
Jul 24, 2008 07:03 AM
Camry V6
Oct 19, 2007 09:13 PM
skaterplayer808
Nov 3, 2006 09:54 PM
