quickflash Flasher control-- HELP PLEASE!!
Hey all, Im new to the board, I just acquired a 2003 camry LE, and I couldnt wait to get a flasher controller. Well I got one from a company called "NOKYA" and I wired it up to my relay harness, there is aBLACK ground,a RED power wire, and A BLUE light source wire, and I only can get my left turn signal working with the unit. But, I located the right turn signal slot and plugged that blue wire in and it works. So, I split the blue wire, and inserted it into both , and they both blink at the same time.
So, I split the red wire and inserted it into the slot right above the white hot wire of the harness, and my P, R, N, D, 2, L lights started blinking fast. Can anyone help me out here?? Its driving me crazy, thanks alot!!!!! |
RE: quickflash Flasher control-- HELP PLEASE!!
1st of all why would you want to make your blinkers blink faster? Whats wrong with the way the blink normally?
ORIGINAL: 05cam 1st of all why would you want to make your blinkers blink faster? Whats wrong with the way the blink normally? |
