quickflash Flasher control-- HELP PLEASE!!
Old Apr 3, 2007 | 04:35 AM
burnone's Avatar
Default quickflash Flasher control-- HELP PLEASE!!
Hey all, Im new to the board, I just acquired a 2003 camry LE, and I couldnt wait to get a flasher controller. Well I got one from a company called "NOKYA" and I wired it up to my relay harness, there is aBLACK ground,a RED power wire, and A BLUE light source wire, and I only can get my left turn signal working with the unit. But, I located the right turn signal slot and plugged that blue wire in and it works. So, I split the blue wire, and inserted it into both , and they both blink at the same time.
So, I split the red wire and inserted it into the slot right above the white hot wire of the harness, and my P, R, N, D, 2, L lights started blinking fast. Can anyone help me out here?? Its driving me crazy, thanks alot!!!!!
Old Apr 3, 2007 | 06:59 PM
05cam's Avatar
Default RE: quickflash Flasher control-- HELP PLEASE!!
1st of all why would you want to make your blinkers blink faster? Whats wrong with the way the blink normally?
Old Apr 4, 2007 | 04:30 AM
burnone's Avatar
ORIGINAL: 05cam
Actually its just a preference, i like the faster blinking rate. I corrected the problem with an exchange of my relay unit for a pair of LED's for the rear turn signal bulbs.... 40.00 less, yet it does the same job. perfectly.
rotorjoe
Jun 11, 2014 10:21 AM
20camry05
Feb 23, 2013 01:40 PM
Octapulse
Jun 21, 2008 12:13 AM
kmalley
Nov 7, 2007 11:08 AM
neenie484
Mar 17, 2007 09:44 AM
