1997 Camry Driver's Seat Won't Raise/Lower
I have a 1997 Camry, as the title says. The driver's seat will not raise or lower when I turn the manual knob. The knob itself it fine, as is the splined shaft.
I took the seat out of the car, and I see that when I turn the knob, the small gear that is supposed to raise the seat does not turn. Is there a fix other than buying a new seat? If I need a new seat, I welcome your advice on finding one. Thanks. |
Probably a better question: what other model years or other vehicle models have seats that are the same as the 1997 Camry? My search of the auto salvage databases has been pretty narrow. If I knew a range of years or some other models that are compatible, then I think I would improve my chances of a hit significantly.
Thanks in advance. |
