2007-UP Camry Front Turn Signal bulb Replacement how to
Gen 6 Camry Front Turn Signal and Parking Light Bulb Change How To DIY
Since nobody really did the how to in picture, here is my DIY contribution Apparently in the manual- it desc removing the bumper to access the headlight- no wonder why Toyota charges so much for labor! 1: Jack up car and remove front wheel, you can also do this just by turning the wheel, but I was doing this for the first time and wanted some space. http://i235.photobucket.com/albums/e...09132Large.jpg 2: Remove the 3 bolts from the front plastic bumper cover undertray and 1 lateral clip holding the fender liner to the fender (I did not take pictures of these but should be self explanatory) http://i235.photobucket.com/albums/e...09133Large.jpg 3: Pull out the fender liner. If you look up into the fender area, you can see and access the front turn signal bulb and parking light. http://i235.photobucket.com/albums/e...09135Large.jpg 4: Twist out the bulbs from the socket and replace, Voila you have changed the bulb! http://i235.photobucket.com/albums/e...09136Large.jpg 5: Reassembly steps in reverse order toyotanation sucks |
