Old Aug 26, 2015, 01:52 PM
How-Tos on this Topic
Browse all: Exterior Guides
Print Wikipost
2007-UP Camry Front Turn Signal bulb Replacement how to
Old Oct 3, 2009 | 02:24 PM
3rdgeargrndrr's Avatar
Lightbulb 2007-UP Camry Front Turn Signal bulb Replacement how to
Gen 6 Camry Front Turn Signal and Parking Light Bulb Change How To DIY
Since nobody really did the how to in picture, here is my DIY contribution
Apparently in the manual- it desc removing the bumper to access the headlight- no wonder why Toyota charges so much for labor!
1: Jack up car and remove front wheel, you can also do this just by turning the wheel, but I was doing this for the first time and wanted some space.
2: Remove the 3 bolts from the front plastic bumper cover undertray and 1 lateral clip holding the fender liner to the fender (I did not take pictures of these but should be self explanatory)
3: Pull out the fender liner. If you look up into the fender area, you can see and access the front turn signal bulb and parking light.
4: Twist out the bulbs from the socket and replace, Voila you have changed the bulb!
5: Reassembly steps in reverse order
toyotanation sucks
krsnikxx
Dec 6, 2013 06:37 PM
aznplayaz
Feb 12, 2012 02:40 PM
aznplayaz
Jul 23, 2011 12:47 AM
dreis13
Mar 26, 2008 05:47 PM
cedric
Apr 13, 2007 02:12 AM
