2009 Camry Hybrid - Cold air on passenger, only hot on driver
In my 2009 Camry Hybrid, I can only get HOT air out of the driver side vents while the passenger side vents blow the correct COLD. Any advice would be appreciated
Does the climate system have a "Dual" control? The knob adjust passenger/driver temps separately.
(Post 99810)
Does the climate system have a "Dual" knob? The knob adjust passenger/driver temps separately.
Do the controls work?
(Post 99815)
Would suspect an air blend door motor has failed. This door opens/closes to change the mixture of hot/cold air to the vent.
(Post 99827)
See link below for location of actuator. Typically if the actuator motor is working the door is moving. Its the motor that typically fails.
https://static.cargurus.com/images/s...-1600x1200.png Also check coolant level and Freon level in A/C. There may be a sight glass on the A/C dryer to allow watching Freon fluid action during compressor on/off operation. |
(Post 99835)
If the Freon level is too, one side can blow hot.
