2009 Camry Hybrid - Cold air on passenger, only hot on driver
Old Feb 1, 2019 | 08:59 AM
swingking03's Avatar
Default 2009 Camry Hybrid - Cold air on passenger, only hot on driver
In my 2009 Camry Hybrid, I can only get HOT air out of the driver side vents while the passenger side vents blow the correct COLD. Any advice would be appreciated
Old Feb 1, 2019 | 10:54 AM
Does the climate system have a "Dual" control? The **** adjust passenger/driver temps separately.
Old Feb 1, 2019 | 11:02 AM
Does the climate system have a "Dual" ****? The **** adjust passenger/driver temps separately.
Yes, it has dual climate controls.
Old Feb 1, 2019 | 08:27 PM
Do the controls work?
Old Feb 2, 2019 | 07:51 PM
It works on the passenger side but not the driver side.
Old Feb 3, 2019 | 11:52 AM
Would suspect an air blend door motor has failed. This door opens/closes to change the mixture of hot/cold air to the vent.
Old Feb 3, 2019 | 04:58 PM
The motor under the driver's side dash near the gas pedal appears to be moving properly. How do I access the blend door to ensure it is connected to the motor properly?
Old Feb 3, 2019 | 08:16 PM
See link below for location of actuator. Typically if the actuator motor is working the door is moving. Its the motor that typically fails.
https://static.cargurus.com/images/s...-1600x1200.png
Also check coolant level and Freon level in A/C. There may be a sight glass on the A/C dryer to allow watching Freon fluid action during compressor on/off operation.
Old Feb 4, 2019 | 11:15 AM
Yes, that motor is moving and cog is properly aligned.
Old Feb 4, 2019 | 01:04 PM
If the Freon level is too, one side can blow hot.
Chao.0724
Jan 7, 2023 04:17 PM
NYGMEN
Jun 21, 2018 03:51 PM
Ervin Lenzy
Dec 15, 2016 05:52 PM
steve2d
Jan 25, 2010 07:58 PM
camrycalichick
Mar 27, 2009 03:17 PM
