2018 Camry - 2 windows not rolling down after battery change
I have a 2018 Camry. After a battery change, the front passenger's side window and the back driver's side window will not roll down. These 2 windows will not operate from the door switch or the master control. The other 2 windows operate normally from the door switch and the master control.
Any ideas? |
Originally Posted by banastre_tarleton
(Post 108925)
Any ideas? I ordered a new aftermarket master switch from Amazon. I hope it works. I don't want to pay $400 for a switch. |
Assume it’s NOT a damaged switch issue but related to the disconnected the battery. The windows and doors locks are controlled by a computer. Disconnecting power to the computer can cause operational problems.Search the internet on resetting Camry windows and door locks. This involves some method of using the cars door lock and window switches as holding one switch up or down for X seconds, etc. Does this BEFORE changing any switches!
(Post 108929)
After doing the reset procedure did you fully push the switch briefly to the “DOWN” and “UP” positions. If done did the power window switch start blinking?
If nothing works disconnect battery again. Reconnect with a single movement to prevent arcing. |
