5 hp compressor, 60 gallon - What type of compressor hose do you use?
Looking for 100 feet, 3/8 and rubber Goodyear but can be a struggle with it but has good qualities. There are synthetics, hybrids but worried of burst and wear and tear. Your thoughts for you large compressor guys?
Not a mechanic but want something I can count on. |
I use Parker Push Lok 801-6 (3/8 inch) which is a synthetic. Bought it used 20+ years ago and its still OK today. Its industrial quality!
https://www.shopcross.com/parker-801...se-38-id-black Goodyear Instagrip is supposed to be about the same. If wanting someone for higher pressure and temps might look at Parker Push Lok Plus 836. |
Reply Thanks Will check it out.
I was also wondering why are some hoses 250 psi and some 300 psi. Who needs this high pressure? The 250 psi is cheaper. |
Could be because the hose can also be used for hydraulic oil which can have have pressures.
Ok. Makes sense.
