5 hp compressor, 60 gallon - What type of compressor hose do you use?
Old Nov 29, 2019 | 12:53 PM
wdc123's Avatar
Default 5 hp compressor, 60 gallon - What type of compressor hose do you use?
Looking for 100 feet, 3/8 and rubber Goodyear but can be a struggle with it but has good qualities. There are synthetics, hybrids but worried of burst and wear and tear. Your thoughts for you large compressor guys?
Not a mechanic but want something I can count on.
Old Nov 29, 2019 | 02:46 PM
I use Parker Push Lok 801-6 (3/8 inch) which is a synthetic. Bought it used 20+ years ago and its still OK today. Its industrial quality!
https://www.shopcross.com/parker-801...se-38-id-black
Goodyear Instagrip is supposed to be about the same.
If wanting someone for higher pressure and temps might look at Parker Push Lok Plus 836.
Old Nov 29, 2019 | 06:48 PM
wdc123's Avatar
Reply Thanks Will check it out.
I was also wondering why are some hoses 250 psi and some 300 psi. Who needs this high pressure? The 250 psi is cheaper.
Old Nov 30, 2019 | 02:28 PM
Could be because the hose can also be used for hydraulic oil which can have have pressures.
Old Nov 30, 2019 | 04:14 PM
wdc123's Avatar
Ok. Makes sense.
Electroman
Oct 1, 2019 03:03 PM
patk
Apr 17, 2013 10:51 PM
larrys
Jul 30, 2011 10:45 AM
hashubek
Sep 1, 2008 11:46 AM
59coop
Jul 14, 2008 12:41 PM
