90 Camry ignition lockset and switch replacement
Hello, anybody replace lockset and switch on a 88-91 Camry? Need to know location of lock pin for removing lockset and how to remove switch? Got steering upper housing separated from lower housing but won't remove. Do I need to remove lower dash? Thanks!
You want to replace the switch or ign key barrel?
Remove lower finish panel under the lower housing of steering wheel. The switch is behind the switch body and held on by a bolt. The barrel can be removed by inserting the ign key, turning to ACC. Then pressing a button on the side of the switch body with a pin and pulling it out. |
