90 Camry ignition lockset and switch replacement
Old Mar 14, 2015 | 03:33 PM
Johnjacobsen's Avatar
Default 90 Camry ignition lockset and switch replacement
Hello, anybody replace lockset and switch on a 88-91 Camry? Need to know location of lock pin for removing lockset and how to remove switch? Got steering upper housing separated from lower housing but won't remove. Do I need to remove lower dash? Thanks!
Old Mar 14, 2015 | 08:45 PM
You want to replace the switch or ign key barrel?
Remove lower finish panel under the lower housing of steering wheel.
The switch is behind the switch body and held on by a bolt.
The barrel can be removed by inserting the ign key, turning to ACC. Then pressing a button on the side of the switch body with a pin and pulling it out.
spiman2u
Jan 15, 2012 12:23 PM
papatodd2010
Mar 13, 2010 11:06 AM
SIGNMAN
Jul 15, 2009 01:59 PM
machine
Jul 15, 2009 01:58 PM
thevillageidiot
Jul 12, 2006 02:03 AM
