95 Toyota camry
When do you know your fuel pump is going bad
[QUOTE=gene5402;88574]When do you know your fuel pump is going bad and how much pressure need. I had car tune up at time it be hard to start up.
95 Toyota Camry
[QUOTE=gene5402;88575]
Originally Posted by gene5402
(Post 88574)
[QUOTE=gene5402;88576]
You know when it goes bad when no fuel gets to the engine, fuel lines are void of fuel before the pressure regulator, typically.
From the fuel filter when you remove it and turn the ignition key there should be a squirt of fuel, If no fuel is visible than there is a problem with the fuel pump.
