96 Camry, engine light #2 cyl misfire
I have a 96 camry 2.2 that has the engine light on and code indicates #2 cyl misfire. I have cleared it several times and after a few minutes the same code appears. The plug is sparking. I am wondering if I have a bad fuel injector? Any thoughts?
The Autozone website may have an fuller explanation of the code to aid you in troubleshooting. The site has a pretty good owner repair section.
Rarely do injectors fail or plug up but it does happen. The ohm reading of the injector solenoid should be 13.4-14.2 ohm. Use a section of rubber hose as a stethoscope to listen for the injector working and compare the noise to the other injectors. Sometimes the ECU coolant temp sensor can cause strange problems with these codes. |
REPLACE the plugs, even if sparking does not mean plugs good, wire check for continuity or replace,
I agree with beige. Had a similar problem but I had just installed plugs and loose connection. The rear plugs are hard but do able. Many videos , info on it without removing many parts.
