Door open chime location
Where is the chime located the chimes when the key is in the switch and you open the door. I know it's under the dash, but where? I also know I can remove the key and it will stop. I don't ever want to here the chime again, if I lock my keys in the car its my problem.
Thanks |
Year of car?
06 Camry LE
Not sure.
It is either attached to the combination meter board or mounted on it. Mounted means no external wiring-part of the circuit system. Either way you will need to remove the combination meter to find it. |
Well that sucks, any other way to disable the key in switch chime?
There may be a unlock switch on the ign cylinder. When the key is inserted the switch closes. Possibly disconnecting a wire to the switch would keep the circuit open. Not sure what this would have on the operation of other circuits, if any.
I have the exact same problem. This chime is super loud and ultra annoying. I have an 1987.
