Door open chime location
Where is the chime located the chimes when the key is in the switch and you open the door. I know it's under the dash, but where? I also know I can remove the key and it will stop. I don't ever want to here the chime again, if I lock my keys in the car its my problem.
Thanks
Thanks
Not sure.
It is either attached to the combination meter board or mounted on it. Mounted means no external wiring-part of the circuit system.
Either way you will need to remove the combination meter to find it.
There may be a unlock switch on the ign cylinder. When the key is inserted the switch closes. Possibly disconnecting a wire to the switch would keep the circuit open. Not sure what this would have on the operation of other circuits, if any.
azizmak
Oct 12, 2012 10:28 PM
stormy76
Jul 20, 2010 06:40 AM
azizmak
Aug 2, 2006 09:22 PM
cmrylovr
Jul 30, 2006 05:10 PM
