Draining gas from 1995 Camry V6 LE Sedan
Working on my Camry for a while and want to drain the old gas. Can anyone tell me if I can just place a hose in the filler hole and pump it out or will I run into a screen.
I would then have to disconnect the hose under the car , remove screen and drain from there. Thank You. |
The issue will be with the small diameter flapper plate where the nozzle goes into the filler tube. The small hole and the plate make it very challenging to get a hose down into the tank. There is no screen or check valve (used to stop spillage in case of a roll over). Perhaps a small diameter tube having some rigidity to allow being forced past the flapper might work.
