Draining gas from 1995 Camry V6 LE Sedan
Old Nov 1, 2021 | 06:16 AM
wdc123's Avatar
Default Draining gas from 1995 Camry V6 LE Sedan
Working on my Camry for a while and want to drain the old gas. Can anyone tell me if I can just place a hose in the filler hole and pump it out or will I run into a screen.
I would then have to disconnect the hose under the car , remove screen and drain from there.
Thank You.
Old Nov 2, 2021 | 11:22 AM
The issue will be with the small diameter flapper plate where the nozzle goes into the filler tube. The small hole and the plate make it very challenging to get a hose down into the tank. There is no screen or check valve (used to stop spillage in case of a roll over). Perhaps a small diameter tube having some rigidity to allow being forced past the flapper might work.
wdc123
Oct 12, 2017 12:08 PM
TheWog
Sep 30, 2011 10:51 AM
tylerhopuma5
Oct 9, 2010 09:36 PM
tylersix6
Feb 4, 2009 03:37 PM
Esteban
Jul 27, 2007 01:54 PM
