headlight stays off in on position on 92' sv32 model
any help guys,ive changed bulbs,light switch , i see no headlight relay in fuse box in engine bay .
Does the car have daytime running lights or auto off lights? Canada or USA car? Do the tail lights work?
nope, has no day time running lights or auto off, just a regular japanese sv32 camry
Use a volt meter to check for 12v at the headlight bulb socket when the headlight are turned on.
Note the headlight relay turns the 12v power on but the light switch selection grounds the bulb to complete the selected circuit. Headlight relay is in a fuse/relay box in engine compartment. The box has one side that is at an angle. https://www.rockauto.com/en/catalog/...amp+relay,3400 |
thanks, mistake ,there is a headlight relay inserted ,ive check the chassis grounds near the light connectros ( 3 black and white wires)
