headlight stays off in on position on 92' sv32 model
Use a volt meter to check for 12v at the headlight bulb socket when the headlight are turned on.
Note the headlight relay turns the 12v power on but the light switch selection grounds the bulb to complete the selected circuit.
Headlight relay is in a fuse/relay box in engine compartment. The box has one side that is at an angle.
https://www.rockauto.com/en/catalog/...amp+relay,3400
