Installing new timimg belt - What is this part I broke?
It is the white female plug in the picture. The male plug wire (single wire) broke off from harness and also lost male plug. Is this a compressor connection or knock sensor? Where to find?
https://cimg6.ibsrv.net/gimg/www.cam...91162bab6d.jpg https://cimg9.ibsrv.net/gimg/www.cam...e11414a2de.jpg |
Forgot 1995 Camry V6 LE Sedan
V-6 engine?
White color sensor may be the oil pressure switch. It's an on/off switch, single wire, not shielded harness wire. Use whatever you got to connect the harness wire to the sensor terminal and call it good. |
Thanks, Toyomoho,
Once you gave me the description found the part at YOTASHOP Toyota. Oil Pressure Sensor Connector With Wire (CONNECTOR F) 90980-11363. Fit perfect or it is also easy to do a simple wire connection as Toyomoho mentioned. Oh, it's a V6. |
Great job!
Thanks for posting back with the info. |
