Installing new timimg belt - What is this part I broke?
Old Nov 15, 2021 | 06:52 AM
wdc123's Avatar
Default Installing new timimg belt - What is this part I broke?
It is the white female plug in the picture. The male plug wire (single wire) broke off from harness and also lost male plug. Is this a compressor connection or knock sensor? Where to find?
Old Nov 15, 2021 | 06:53 AM
wdc123's Avatar
Forgot 1995 Camry V6 LE Sedan
Old Nov 15, 2021 | 11:38 AM
V-6 engine?
White color sensor may be the oil pressure switch.
It's an on/off switch, single wire, not shielded harness wire.
Use whatever you got to connect the harness wire to the sensor terminal and call it good.
Old Dec 4, 2021 | 06:04 PM
wdc123's Avatar
Thanks, Toyomoho,
Once you gave me the description found the part at YOTASHOP Toyota. Oil Pressure Sensor Connector With Wire (CONNECTOR F) 90980-11363. Fit perfect or it is also easy to do a simple wire connection as Toyomoho mentioned. Oh, it's a V6.
Old Dec 5, 2021 | 01:41 PM
Great job!
Thanks for posting back with the info.
wdc123
Nov 15, 2021 06:50 AM
Philbert86
Apr 3, 2021 11:56 PM
goldenphoenix
Mar 12, 2021 08:39 PM
stickshift
Jun 5, 2013 01:35 PM
brianjrealtor
Jun 19, 2011 08:09 PM
