Chicagopaul2010 |
10-02-2022 06:29 PM |
p0171, also MAF screw size? 2012 Camry SE
My check engine light came on along with the traction control light and the car gave me the P0171 code. This is the snapshot:
Code:
02 DTC that caused freeze frame data Trouble Code P0171 triggered Freeze
Frame. Code Def - System Too Lean
Bank 1
03 Fuel System Status Closed loop - using all oxygen sensor(s)
as feedback for fuel control
04 Calculated Engine Load Value 19.2 %
05 Engine Coolant Temperature 91 °C, 196 °F
06 Short Term Fuel Trim Bank 1 18.8 %
07 Long Term Fuel Trim Bank 1 27.3 %
0C Engine RPM 661 rpm
0D Vehicle Speed 0 km/h, 0 MPH
0E Timing Advance for #1 cylinder 14.0 °
0F Intake Air Temperature 58 °C, 136 °F
10 Mass Air Flow Rate 1.57 g/s, 0.21 lb/min
11 Absolute Throttle Position 16.9 %
15 O2 Bank 1 - Sensor 2 - Short Term Fuel Trim 99.2 %
15 O2 Bank 1 - Sensor 2 - Oxygen Sensor Voltage 0.000 V
1F Run Time Since Engine Start 240 seconds
24 Wide Range O2S: Bank 1 - Sensor 1 - Equivalence
Ratio
1.128 λ
24 Wide Range O2S: Bank 1 - Sensor 1 - Voltage 3.764 V
2E Commanded Evaporative Purge 0.0 %
30 # of Warm-ups Since Codes Cleared 4 #
31 Distance Traveled Since Codes Cleared 123 km, 76 mile
33 Barometric Pressure 100 kPa, 30 inHg
34 Wide Range O2S: Bank 1 - Sensor 1 - Current 0.172 mA
34 Wide Range O2S: Bank 1 - Sensor 1 - Equivalence
Ratio
1.128 λ
3C Catalyst Temperature Bank 1 - Sensor 1 394.8 °C, 742.6 °F
3E Catalyst Temperature Bank 1 - Sensor 2 99.2 °C, 210.6 °F
42 Control Module Voltage 13.300 V
43 Absolute Load Value 9.4 %
44 Commanded Equivalence Ratio 0.999 λ
45 Relative Throttle Position 0.0 %
47 Absolute Throttle Position B 48.6 %
49 Accelerator Pedal Position D 16.1 %
4A Accelerator Pedal Position E 32.2 %
4C Commanded Throttle Actuator 16.9 %
4E Time since Trouble Codes Cleared 244 minutes
51 Fuel Type 0 N/A
53 Absolute Evap System Vapor Pressure 100.645 kPa, 404.053 inH O₂
65 Auxiliary Inputs / Outputs 0
I looked everywhere I thought I could to see if I could see any holes or rot on the pipes but I couldn't find anything; I don't really hear any hissing except maybe around the (if you're facing the front of the car and looking down at the whole engine bay) rear right area, but I swear I've always heard that whenever I opened the hood, and I've owned this car for many years.
I replaced the MAF sensor and reset the code, lost one of the damn screws ( AND I CAN'T FIND THE DAMN SIZE ANYWHERE, PLEASE HELP ME).
I don't have the live data with me but as I was driving around the fuel trims still looked terrible and my gas mileage was just garbage, so I either have a leak i'm not finding or I don't know, OR it was the MAF sensor but the missing screw is throwing everything off, or maybe it's something I don't even know to look for. I am a novice DIY after all.
Can anyone help me make heads or tails of this?
