Parking Brake Doesn't Work after Changing Rear Brake Shoes
Today, I completed a rear brake job, changing the rear shoes, without problem. I carefully noted spring positions and the parking brake assembly and confirmed that on reassembly everything matched how it looked before disassembly.
I was unable to remove the parking brake cable from the metal structures that attach to the brake shoes, so I only changed the rear brake shoe and all springs (there was no replacement star wheel in my hardware kit). I did NOT damage or excessively twist the parking brake cable. There is no dragging and my brakes are quiet, but the parking brake does NOT work. I tightened the nut in the cabin area all the way down, such that I only get 7 clicks on the parking brake when I pull on it. Suggestions? |
1 Attachment(s)
thats about right...... only go that far if replacing the actual cable 7 clicks and the drums don't hold ... almost got it .... you are close two ways 1...current trend in workshops take drum off again click up that top adjuster (in pic ) so you can get the drum back on should be some drag noise on the shoes ... when you try to spin the drum fit the tyre do the other side same way how many click on the lever hold the tyre adjust the handbrake cable 2..the old school fix with the handbrake lever off rear wheels off the ground safely (car stands ) you go to the backing plate of the rear brakes you should see a plug or a slot with a screw driver or brake adjusting tool search inside till you find that upper adjuster in pic when you click the adjuster the right way the drum is holding the tyre ...then back the adjuster off so there is some drag you do the other side drum the same way then test the hand brake adjust the handbrake cable if required if done correctly i would be happy with 5 clicks and the rear handbrake holds both wheels Attachment 3811 |
When I finished installing the new brake shoes, I had to tighten the star wheel all the way to get the drum on. Is that the problem?
When I'm rotating that star and facing it, do I push it away or toward me? Thanks |
Just to be clear, seven clicks is the most number of clicks I can pull the parking brake (it was 14 clicks without response when I first adjusted it). Even when I pull it seven clicks, the parking brakes does NOT engage.
5 to 7 clicks is good if the handbrake holds ..
you are spot on that star wheel has to be adjusted again outwards you need the new brake shoes to drag on the drum as you rotate the tyre by hand direction is trial and error .. the star wheel adjuster is a different rotation for either side .of the car ..to make the shoes go out to touch the drum work that out ... and your brakes should be be good to go if still a problem the handbrake cables might be stretched or the brake drums out of round |
