Parking Brake Doesn't Work after Changing Rear Brake Shoes
Old Dec 27, 2015 | 07:50 PM
1989_Camry's Avatar
Default Parking Brake Doesn't Work after Changing Rear Brake Shoes
Today, I completed a rear brake job, changing the rear shoes, without problem. I carefully noted spring positions and the parking brake assembly and confirmed that on reassembly everything matched how it looked before disassembly.
I was unable to remove the parking brake cable from the metal structures that attach to the brake shoes, so I only changed the rear brake shoe and all springs (there was no replacement star wheel in my hardware kit). I did NOT damage or excessively twist the parking brake cable.
There is no dragging and my brakes are quiet, but the parking brake does NOT work. I tightened the nut in the cabin area all the way down, such that I only get 7 clicks on the parking brake when I pull on it. Suggestions?
Old Dec 27, 2015 | 08:16 PM
dirty hands's Avatar
thats about right...... only go that far if replacing the actual cable
7 clicks and the drums don't hold ... almost got it .... you are close
two ways
1...current trend in workshops
take drum off again
click up that top adjuster (in pic ) so you can get the drum back on
should be some drag noise on the shoes ... when you try to spin the drum
fit the tyre
do the other side same way
how many click on the lever hold the tyre
adjust the handbrake cable
2..the old school fix
with the handbrake lever off
rear wheels off the ground safely (car stands )
you go to the backing plate of the rear brakes you should see a plug or a slot
with a screw driver or brake adjusting tool search inside till you find that upper adjuster in pic
when you click the adjuster the right way the drum is holding the tyre ...then back the adjuster off so there is some drag
you do the other side drum the same way
then test the hand brake adjust the handbrake cable if required
if done correctly
i would be happy with 5 clicks and the rear handbrake holds both wheels
Old Dec 27, 2015 | 08:54 PM
1989_Camry's Avatar
When I finished installing the new brake shoes, I had to tighten the star wheel all the way to get the drum on. Is that the problem?
When I'm rotating that star and facing it, do I push it away or toward me?
Thanks
Old Dec 27, 2015 | 09:01 PM
1989_Camry's Avatar
Just to be clear, seven clicks is the most number of clicks I can pull the parking brake (it was 14 clicks without response when I first adjusted it). Even when I pull it seven clicks, the parking brakes does NOT engage.
Old Dec 27, 2015 | 09:21 PM
5 to 7 clicks is good if the handbrake holds ..
you are spot on
that star wheel has to be adjusted again outwards
you need the new brake shoes to drag on the drum as you rotate the tyre by hand
direction is trial and error ..
the star wheel adjuster is a different rotation for either side .of the car ..to make the shoes go out to touch the drum
work that out ... and your brakes should be be good to go
if still a problem
the handbrake cables might be stretched or the brake drums out of round
bkpez
Apr 17, 2011 09:34 AM
drjeep1959
Nov 22, 2010 11:12 AM
baiteman
Sep 25, 2009 09:00 PM
beunos24
Jul 8, 2008 04:01 PM
drducttape
Sep 24, 2007 11:31 PM
