Stuck rear rotor - not rusted to hub
I have a 2012 Camry Hybrid with a rear rotor that will not come off.
The problem is not the rust around the hub I've already dealy with that, the rotor actually moves 1/2" from hub but stops. I think it is jamming up on the parking brake. A friend suggested moving the adjustment knob for the parking brake but I can't find it through the little hole. Any ideas? |
Make sure emergency brake is off.
The adjuster is at the bottom of the hub. Rotate hole in rotor until it is at the bottom. The adjuster looks like a star wheel (has nobs). Use screw driver to rotate the nobs downward. This will back off the shoes to allow the rotor to come off. |
