Union bolt stuck on power steering pump
I am a total newbie not only on this forum but also working on my car.
I am in the process of replacing my power steering pump. However, the union bolt on top is unmovable. It almost seems like the gasket melted under the bolt. Anyway, I cannot get the thing to budget all which has obviously stalled all progress. Any ideas on how to get that bolt out? Thanks 1996 Camry 4cyl 2.2L |
The gasket may be two gaskets combined. The lower and upper with a connecting band in between. The bolt is torqued to 38 ft lbs.
If there is a wiring harness going to the fitting make sure you remove the pressure switch on top before the fitting. |
