1983 toyota camry le no start
seems to be no spark at plug feeling it might be coil as it is in dist anyways any ideas it overall is good ride i am giving my kids but the ign problem is driving me nuts
The coil can be replaced.
Determine if you can separate the coil high voltage output lead from the distributor cap. Then check for high voltage (spark) at the coil lead when cranking the engine. Also check fuses, make sure the coil is getting 12V power. |
