94 Camry V6 Alarm Issue
Hi I recently bought 94 Camry V6 XLE, which has an alarm installed. I don't know if its factory fitted? There is a small on/off siwtch near the parking brake and hood latch. The person I bought did not told me how to off the alarm if it goes on.
Once I mistakenly switched off this switch and later turned it on and after some time when I entered the car, alarm went on, car would not start. After 20 minutes of struggle, inserting key turning ignition on, changing alarm switch between on and off, I managed to off the alarm.Same thing happened again during oil change when battery was reconnected after examination and this time I spent 30 minutes. The mechanic also did not know to off the alarm. Can anybody tell me the steps to off the alarm when it goes on? |
RE: 94 Camry V6 Alarm Issue
itsounds likeyou have an aftermarket alarm...take it to a local stereo shop.. they should be able to help...with my aftermarket alarm...the way i turn it off manualy is....turn the key on engine not running turn the tuggle switch off and the alarm LED will light solid...
any alarm has a manual switch to turn off the alarm. Put your ignition key into "on" then turn off the alarm using the switch.
