Accessories wont cut off...
I have a 07 Camry and once the key is out of the ignition switch, all of the accessories remain on. Lights, clock, radio...ect stay on.
I changed the ignition switch and still have the same problem. Napa cant pull up an Accessory Relay...so what could be the problem? It sounds like a relay but which relay is it and whats the name of the relay? And can I get it from the local autoparts store... |
ACC relay located in Instrument Panel junction box on far left side of panel behind ash tray/coin box. Relays are on lower part panel, center relay ACC.
1 Attachment(s)
is this relay gray square or blue rectangle?Attachment 3122
so i changed the 2 blue relays and problem still persists.
the problem is the car is acting like the key is in the ignition with just the acc on. the doors wont lock with the remote nor with the lock switch inside. |
The ACC would be the larger sized gray one having the scuff mark on top. The one between the two smaller blue ones.
Remove the relay and determine if the items now turn off. |
i removed the gray relay and swapped it with the gray relay from the far left and still acc stay on.
any suggestions anyone? its not the open door sensors cause they all check out. the problem was intermitent for a couple of days but now is permanent. are there any other relays in the car that would affect the acc like this? could it be the factory alarm even though it working fine?
Remove the relay, don't swap it. Determine if clock and radio off.
If now off, replace relay and determine if now on. If so, remove AM1 fuse and determine if now off. |
i removed ecu acc1 fuse from fuse panel and that cut off the clock. i removed the gray relays and nothing changed. acc still on without key in
