All electrical is dead - 1999 Camry
I was changing my timing belt and forgot to disconnect the battery when I moved the alternator. I blew the 100 amp alternator fuse. Unfortunatly, I didn't learn from my mistake and when replacing the 100 amp fuse by the battery I touched my wrench between the negative terminal and the bolt on the fuse. It sparked for a few seconds and now may car is "dead." I have no electrical power anywhere. I havn't found a bad fuse yet. I have checked most of the fuses by the battery. I need some guidance on what to check to diaganose this issue.
Thanks, Matt |
I'm thinking my issue is related to this thread. https://www.camryforums.com/forum/en...problem-39768/
When I get back from work tomorrow I'll look for the fusable link between the battery and the alt 100AMP fuse, Any other ideas? |
Check power between 100A ALT fuse and +12v battery. There is a fusible link in the electrical cable between the two.
