Bulb Question
Does anyone know the size of the bulb that is found behind the 97-01 temp control? Its a small bulb, smaller than the 194s. I cant find it n e where [:@]
RE: Bulb Question
probably a 74
http://www.sylvania.com/ConsumerProd...de/default.htm that probably wont help with your spec question tho. |
RE: Bulb Question
Hey are you bulbs going on and off or is it actually out. Mine had a problem flickering so i bought a new Heat AC controller on ebay for 15 bucks and it fixed the whole thing
RE: Bulb Question
yeah there is a loose connection to that bulb usually. i think mine fixed itself over time.
RE: Bulb Question
Hey I wanted to change the color of my bulbs behind the temp controls from green to red and when I unscrewed the control box and right before I could take it out, the box wouldn't let me bring it out far enough to where I could get to the bulbs because there are wires behind there? How did you get by all this? can the wires be unplugged?
RE: Bulb Question
i was going to fix a bulb that would go off and on in the hvac area you speak of but like you, i couldnt pull it out enough. But if you yank a little harder it does come out more and you can see in the back how to get off the cables. You do need to take the radio out for sure.
