A/C Light Flashes and A/C stops working 2003 Camry
2003 Camry .. When the light flashes the A/C will not work .I turn it off and back on and it is okfor a while and it starts again . My two rad fans are on almost all of the time but the engine is not overheating :confused:
The A/C compressor magnetic clutch relay is could be defective.
Old relay P/N 90987-02022. Check fuse/relay box in engine compartment next to battery. New replacement relay P/N 90987-02028. There is a technical service bulletin on this: http://www.toyotapart.com/AC_LIGHT_F...T-EL011-05.pdf The relay was a common problem, an internet search will find lots of hits. It is possible the problem can be something else but check the relay first. Also check cabin air filter condition. Located under the dash above heater blower owners manual should have info. |
Originally Posted by Gabe
(Post 80562)
