Camshaft sensor wiring help
Hi all. I have a 09 camry v6 3.5. My camshaft sensor connector busted into pieces when I unplugged it. I have a replacement but not sure which wires go with which. I have green, blue, and green with red stripe wires. I know the blue goes in the middle not sure about the other 2. It's the sensor on the front side in between #2 & 4 cylinders. Was hoping someone might have a pic or diagram. I've searched to no avail. Thank you in advance 🙏
My info has blue in the middle.
The terminals are labeled 1, 2, 3. 1 is green/red, 2 is blue, 3 is light green Remove Bank 1 exhaust sensor wiring plug The wiring order 1, 2, 3 is yellow, black, red. The other sensor plugs wiring is as in 1, 2, 3: White, black, red. Blue, light green, yellow. Compare colors to get the order of the wires as in 1, 2, 3. |
Thank you soo much toyomoho!!
