Camshaft sensor wiring help
Old Feb 1, 2023 | 02:47 PM
ledbetter94's Avatar
Default Camshaft sensor wiring help
Hi all. I have a 09 camry v6 3.5. My camshaft sensor connector busted into pieces when I unplugged it. I have a replacement but not sure which wires go with which. I have green, blue, and green with red stripe wires. I know the blue goes in the middle not sure about the other 2. It's the sensor on the front side in between #2 & 4 cylinders. Was hoping someone might have a pic or diagram. I've searched to no avail. Thank you in advance 🙏
Old Feb 1, 2023 | 03:48 PM
My info has blue in the middle.
The terminals are labeled 1, 2, 3.
1 is green/red, 2 is blue, 3 is light green
Remove Bank 1 exhaust sensor wiring plug
The wiring order 1, 2, 3 is yellow, black, red.
The other sensor plugs wiring is as in 1, 2, 3:
White, black, red.
Blue, light green, yellow.
Compare colors to get the order of the wires as in 1, 2, 3.
Old Feb 1, 2023 | 04:22 PM
Thank you soo much toyomoho!!
bluedogz
Apr 2, 2021 08:07 PM
gzcar
Jun 16, 2020 09:47 PM
ggino85
Jan 15, 2017 04:26 PM
asosnoff
Apr 7, 2011 08:16 PM
