engine problems 2005 camry
I have a 2005 Camry 2.4 it turns over but will not run put it on a OBD2 said at first P0353 I cleared that then it said P0352 cleared that then it said P0351 and that one wont clear changed all 4 spark plugs 2 coils in the middle spark plug second from the right had oil on it changed it now i dont see anymore oil can you help still getting P0351
Do the spark plugs spark when turning the engine over?
yes the engine will run for about a second then shut off
yes the engine runs for about a second then turns off
Check crank and cam sensors.
ok thank you
