fuel guage acuracy altise 05
is the problem in the sender or in the instrument panel
the tank is empty but the guage is at 1/4 or a bit less is there any fix known i guess the pump and sender are in one unit .... have no picture of it thank you |
The sender can be separated from the pump. The float on the sender arm may be stuck, damaged, etc and not fully dropping when tank is empty.
Would look something like item in link below: More Information for DENSO 9550105 Remove rear lower seat cushion, then oval plate on chassis flow to access top of fuel tank and fuel tank pump-sender top. |
thank you very much for the picture
under the rear seat is handy will see if rod is bent or float stuck check connections for corrosion and dust etc if the needle moves .. should be able to sort it from there if needle doesnt move properly ..new sender unit |
