fuel guage acuracy altise 05
Old Jan 30, 2014 | 02:15 PM
dirty hands's Avatar
Default fuel guage acuracy altise 05
is the problem in the sender or in the instrument panel
the tank is empty but the guage is at 1/4 or a bit less
is there any fix known
i guess the pump and sender are in one unit .... have no picture of it
thank you
Old Jan 30, 2014 | 04:15 PM
The sender can be separated from the pump. The float on the sender arm may be stuck, damaged, etc and not fully dropping when tank is empty.
Would look something like item in link below:
More Information for DENSO 9550105
Remove rear lower seat cushion, then oval plate on chassis flow to access top of fuel tank and fuel tank pump-sender top.
Old Jan 30, 2014 | 06:13 PM
thank you very much for the picture
under the rear seat is handy
will see if rod is bent or float stuck
check connections for corrosion and dust etc
if the needle moves .. should be able to sort it from there
if needle doesnt move properly ..new sender unit
dirty hands
Jan 15, 2014 05:07 PM
dirty hands
Jan 9, 2014 06:44 PM
Rick AZ
Jul 26, 2013 05:33 PM
elpearl
Oct 9, 2011 12:38 PM
spied1
Sep 2, 2009 08:11 PM
