Help
Check engine light, check vsc light and cruise control stopped working on my 2016 Camry. Any suggestion? All happened simultaneously.
Depending on the problem, when the check light comes on the other systems turn off and with this their lights also come on.
Find out what the issue is that resulted in the check light and fix it. The result may be the other lights turn off. |
[QUOTE=toyomoho;103008]Depending on the problem, when the check light comes on the other systems turn off and with this their lights also come on.
Find out what the issue is that resulted in the check light and fix it. The result may be the other lights turn off.[/QUOTE It says check vehicle stabilization system in the warning box. Don't know if that would help in diagnosing. Will definitely get a auto zone check 1st chance I get |
Yes, get the codes read and post back.
It ended up being the purge valve in the gas tank. Every time I filled the tank the car wouldn't start. Don't get the codes read at auto part stores. Just bite the bullet and take it to Toyota.
Thanks for posting back with the fix.
