Help
Depending on the problem, when the check light comes on the other systems turn off and with this their lights also come on.
Find out what the issue is that resulted in the check light and fix it. The result may be the other lights turn off.
[QUOTE=toyomoho;103008]Depending on the problem, when the check light comes on the other systems turn off and with this their lights also come on.
Find out what the issue is that resulted in the check light and fix it. The result may be the other lights turn off.[/QUOTE
It says check vehicle stabilization system in the warning box. Don't know if that would help in diagnosing. Will definitely get a auto zone check 1st chance I get
