moter won't start because of no spark in spark plug.
I am new to this, so can someone please.please. help me? My car will not start. Motor turns over, but no ignition. I changed spark plug wires, spark plugs, cap&rotor, and starter, but still car does not start. People have advised me to maybe look into ignition coils or ignition module. I am not a very good auto mechanic, but learning as I go along. To anyone out there your help would greatly be appreciated. Thank You very much for listening.
RE: moter won't start because of no spark in spark plug.
this is what you do.. pull out the motor.. and as vin diesel thinks best... with overnight parts from japan, put in a 2JZ-GTE
ok that was no help at all......check the distributor and the computer. the coils could be the problem but if not try that
It should be the coil. change the coil! been there & done that
is your check engine light on when you're cranking....check the igntion rotor turns when your cranking, may your timing belt is broken......did you inspect the coil for cracks (you need to remove the rotor and coil cover to see the crack)...check the primary and secondary winding in your coil...and get a repair manual...
check the distributor and the computer. the coils could be the problem but if not try that !
