moter won't start because of no spark in spark plug.
I am new to this, so can someone please.please. help me? My car will not start. Motor turns over, but no ignition. I changed spark plug wires, spark plugs, cap&rotor, and starter, but still car does not start. People have advised me to maybe look into ignition coils or ignition module. I am not a very good auto mechanic, but learning as I go along. To anyone out there your help would greatly be appreciated. Thank You very much for listening.
is your check engine light on when you're cranking....check the igntion rotor turns when your cranking, may your timing belt is broken......did you inspect the coil for cracks (you need to remove the rotor and coil cover to see the crack)...check the primary and secondary winding in your coil...and get a repair manual...
feanor70115
Feb 4, 2008 01:35 AM
feanor70115
Feb 1, 2008 06:46 AM
