Where is the ECU for rs3000 98 Camry?
[blockquote]
OK. I have located the glass break sensor that is behind the drivers side kick panel. I see wires running from the sensorup/higher in behind the dash. I still can not see the ECU. It has to be further up and somewhere behind the dash... [/blockquote] How do you get to the ECU to push the button to start the programming process??? Does anyone have a link that shows how to get in behind the dash where the security panel and fog light switch are located? Thanks |
Open the panel on the left side of the steering wheel. The panel is; a mirror control, light dimmer, empty, and then the LED security with a microphone. After opening, look up. There should be a black device there. Cut the BLACK zip-tie (this will cause the ECU to fall out of place). There you will be able to obtain the ECU unit
